WTB Kick down lever
RSZ28
8:36 PM
Brownsville, PA
Feedback: 1 / 0 / 0
Looking for kick down lever for 65 b body that is fasten on the 727 transmission. Different than 904. All V8 engines except 273 use the same lever. Thanks
I will look to make sure I have a couple extra. I'm pretty sure i should have 3 or 4
I don't know if it has a part number on it, but the part number is 2264744. Thanks
Like this one correct? If so I'm going to look for the one I haven't modified to work with my huge intake.
Well I found it if this is correct I'm sure it is as it's from a 64 or 65
I'm looking for the lever that fits on the transmission not the kick down rod.
Oh damn sry about that. Are they the same from regular 727 to the push button ones or just cable shift?
Not sure. Maybe someone can chime in on information. Mine is column shift with cables. I would think that since the kick down linkage connects carb and transmission that it wouldn't matter.
If it quits snowing I'll run to my other house and pull one off a junk 727 core and see if it fits my cable trans. But it's coming down pretty good right now
I assume this is it. This is off a 66
That is not what I need. The 66 uses two kick down rods. Your picture shows just the lower rod. The 62-65 uses a single rod. This changes the angle. The lever that is on the end in your picture isn't the correct one needed for single rod. The 65 is flat, yours has a slight bend in it. OEM part number is 2264744.
Hey did you get my 2nd msg with the other picture I sent? I still had one attached to the 65 361
Yes, I got picture, but really need lever similar to the one in Randra's picture that is on the end of the kick down rod. The lever was used from 62-65 on all 727 transmissions with V8 engines except the 273.
I have that lever, PM me if you still need it
