charger parts compatibility
cuda Hunter
1:05 AM
Colorado
I have a 74 charger
Need hood and deck lid.
1. Will 1971-1973 hoods and deck lids work on the 74?
2. Would a big block fit into my small block 74 easily? Change radiator, K frame, tranny mount
drive shaft.
3. Are interior parts mostly the same?
4. Are fenders the same?
Your car is too new for me to know about interchangeability ,but you can put anything in there from a slanty to a 2nd gen hemi!
Might consider a 3rd gen hemi they are considered small blocks but as new as your car is ive got no clue how much room you have even with the 3rd gen hemi its tight
71-74 hoods and deck lids are interchangable except the hoods all have different vents up by the windshield, except 74 has none. This doesn't bother anything except if you are concerned with the window washer squirters since they spray thru the vents on the 71-73 hoods. On 74's they are on the wipers.
A big block will go right in where a small block was. .just make sure you have big block motor mounts on your motor. K frame is fine. Your motor mounts will have to be the 73-74 spool type since 71-2 are different.
You would have to change you radiator to make sure your hoses match up with the water pump or do some different plumbing.
Front fenders are 71 only and 72 only and 73-74 only.
Some interior parts interchange. I was told 71-72 soft upper door panels will not fit a 73-74 door but I have never tried checking that
Tranny mount and driveshaft should work between your small block and big block swap. I did the swap from small to big on my 74 se
I have a 74 charger
drive shaft.
1. According to VFN fiberglass, the '71 - '74 hoods are the same. Same with deck lids.
2. Yes. Nothing is easy, but big blocks were available in Chargers from '71 - '74.
3. Aside from design and colors, I believe the interior components MOSTLY interchange. You had that louvered rear side window thing in '73 - '74.
4. Can't say for sure, but I think the front fenders are the same '72 - '74. The Charger is weird. The inner fenders for a '70 - '71 are the same; '66 - '69 are the same.
Maybe someone else can provide more info. like 400sforever above. Good luck.
Thanks for the replies. Glad to hear that it's not as difficult to change as an e-body.
So can I change the spool type motor mounts to the earlier motor mounts? I've heard that spool types eat some horse power.
If you change the spool mounts to the earlier mounts you would have to change the k member or cut the k member mounts off and change to the older style. . .too much work in my opinion. I've never heard of those mounts eating hp but then again I have a 512 in my 74 so hp in not an issue!
71-71 Chargers are an entirely different car than a 73-74.
73-74 was re-engineered to have less NVH, and has a huge rubber isolated K frame with different rad support, aprons, frame rails, longer torsion bars, an isolated torsion bar anchor crossmember behind the transmission crossmember, a rubber isolated steering column, rubber isolated rear axle
Yes the hoods and trunklids will interchange, but that's it for bolt on body parts.
The fenders and doors from 71-72 will not fit. Fenders have a totally different inner structure due to the totally different inner aprons, rad support of the 73-74 and also the wheel wells were raised up.
Body lines of the doors are completely different to match up with the totally different quarter panels and weigh a ton with the side impact beam inside.
Hoods will physically fit but do have year to year variations listed in previous posts. The trunklids fit, but 73-74 use the large key cylinder with the huge nut retaining it, where the 71-72 trunklids use the smaller clip in cylinder.
Starting in 1973, every engine family uses a different K frame and spool mounts. Big block will not bolt onto a small block K frame
73-74 Charger may resemble a 71-72 from a distance, but they are a completely different car underneath, and are actually closer to a Córdoba structurally.
Put a 71 Charger and a 73 Charger on a hoist and they will look completely different underneath.
Put a 73 Charger and a 79 Córdoba on a hoist, and they will look almost identical.
The 75-79 Córdoba, and all other 75-79 B bodies including the 79-81 4 door St Regis, Newport, Gran Fury, New Yorkers are essentially the same car underneath as your 73 Charger and more interchangeable than a 71-72 Charger is.
You are wrong about big blocks and small blocks using specific k frames in 73 and 74. You can put a big block in a small block car no prob at all. Just make sure you have big block motor mounts on the motor.
all body lines from any 71 or 72 fender totally line up. any one that's says different has never bolted one on . a couple of the mounting holes are off but that's it. the wheel wells on a 73-4 are 1 1/2 inches bigger. the under carriage design was carried all the way from 73- 79 with only slight changes.
Yes, 1971-72 Fender body lines will match the 73-74 door and hood, but 71-72 Doors will not match the 73-74 quarters. Not even close. The 73-74 doors and quarters, and quarter end caps are totally different than the 71-72.
And 71-72 fenders are different where they bolt to the rad support.
E body is just about the easiest to change from small block to big block. Any 66-72 C body can supply a drop in big block engine, Trans and mounts, rad, darn near everything.
71 fenders on anything other than a 71 will look goofy due to the different side marker hole sizes. I put a stroked 400 with headers right into my original 318 74 charger without doing anything other than using big block motor mounts. .so I don't know where all this big block/ small block k member argument is coming from and i don't understand cutting into any inner fender wells either? I'm just speaking from experience from my 74
same here I dropped my 440 right in my 360 powered charger. just a bunch of people guessing without actually building one. my 74 charger has 72 doors on it as well , but they don't fit or line up OK WHATEVER
E bodies aren't that difficult. I was hoping the b body was easier since it is larger and the K frame's are similar to the e body.
Do the b bodies slide out of the bottom on the K frame like the e bodies?
I've opened a can of worms huh. I do like the info. Thanks
are you referring to taking the k member clear out of the car? If so, you can drop it right out from underneath the car if you have it up in the air.
