Are these wheels worth anything??
JD Davis
3:51 AM
Esparto, CA
These are my original 14x6 stock wheels off my '71 SuperBee; one hubcap is slightly dented and pitted, others are in good shape. What are they worth??
I also have one 14x5.5" ralley wheel about the same vintage.
Not sure what they are worth but might be to someone that's restoring a 71 B if the numbers are right. The Rallye wheel came out in 70 and the center is for 70-71 only. How are you measuring the width? From inside of the bead seat or outside?
Thanks for reply; from edge of bead to edge of bead, it's half inch more narrow than my rims. It may have come off my brother's barracuda.
I measured from where the tire would sit, it that makes sense, I guess that's the outside.
14" are hard to even give away. I usually just use 14" as rollers when needed on some project cars to move in & out of the garage or in & out of the trailer for transporting.
