M/E WAGNER PCV VALVE
Bill Monk
12:25 AM
West Virginia
I'm interested in this pcv valve.
http://mewagner.com/?p=444
My question for any of you guys using this is how to make it fit with stock valve covers? The stock valve cover has a 15/16 hole for the grommet and the stem on the stock pcv valve is 7/16. That's where the problem is. The wagner valve is setup for a 3/4 grommet and I am not aware of anyone making a grommet to fit in the 15/16 stock cover with a 3/4 hole in it. (anybody know of one?) I thought about their in line adapter but that would be too small to fit the stock grommet because it would be 3/8 on both ends.....so how did you guys that have it make it work
Bill, that isn't the stock PCV, right. It's a little bigger?
The wagner pcv goes into a 3/4" grommet so it clearly won't fit into the stock grommet which has a 7/16 hole for the stock pcv. What I need is a grommet to fit a stock valve cover 15/16 hole with a 3/4 id hole for the wagner pcv and I can't find that grommet anywhere
Beat me to it, even your local parts stores usually cary a variety.
