- 7:03 AM
- Jan 23, 2009
- New Jersey The State of Tax Theives
Snakeoil24,OK So if i under stand better since your idea is great. The rocker molding is 4 inch tall by 6 feet long. It snaps on on the bottom and it folds over on the top and gets screwed in place on fold. Should i place the Masonite inside the molding and make it a tight fit inside the molding? then make the marks into it where the clip needs to be drilled.
You might try modeling clay. Assemble the clips equally spaced on the molding then apply clay on the body in those locationsThe top of the molding has a folded edge and screwed on bottom. the clips have a index dowl to locate then properly if the holes where still their so they dont cock. The clip has a curve on top that spring loads when yopu slide folded flange behind the clip if that makes sense. I think i get what your saying about the double sided tape. I have to think about that. What if i cover the rocker with some thing soft and press the clips and rocker into it and look for indentations?
