Federal power steering pump?
Terry Kitzman
7:21 PM
S.E. Iowa
Where can I find a federal power steering pump for my 66 - 383 charger. I've checked with classic industries, Summit racing, Rock auto, Tonys parts, and Mancini racing. No luck. Any help would be appreciated. Thanks, Terry
Federal's were not used on 66's. TRW was correct. Maybe your brand term is mixed up, but if you buy a Federal, expecting a TRW, you will not be happy.
Well, here is what I found.
2585532 is the original part number.
https://www.hiltopautoparts.com/pro...g-pump-package-1960-8-with-4-58ths-reservoir/
https://www.ebay.com/itm/NOS-Mopar-...60-1968-With-4-5-8ths-Reservoir-/272688316535
Also found this info:
http://www.bigblockdart.com/techpages/pspumps.shtml
The parts book even says 4 5/8 diameter.
There are numerous interchanges as seen here including the hand written superseed # in my parts book 3685603:
https://books.google.com/books?id=6HblMiBjCWoC&pg=PA79&lpg=PA79&dq=2585532+steering+pump&source=bl&ots=QqNsSasfIr&sig=qrQpDpm0DZJOpXB7Ehffv9hzRZQ&hl=en&sa=X&ved=0ahUKEwicq-DVnr_bAhVDzVMKHfhtDW4Q6AEIfTAN#v=onepage&q=2585532 steering pump&f=false
Then "with key mounting pulley" 2537842
One more note, my 67 parts books lists 2 as well. 2585532 and 2537664(key mtg pulley)
Can't find too much info on that one but what I have done in the past is just bring it to the store and try to match it up as close as possible.
With all those pics, you should be able to see something that looks like it.
Hope that helps.
Bob
I’m looking for a lil help too , I just started a project it’s a 65 coronet 500 with a 361 . No ac , missing the power steering pump and bracket lines but has the gearbox still . Can’t figure out what pump I need and which bracket is required . Any help out there ?
