kelsey Hayes brake valve
daytona71
1:39 PM
BC
I have a Kelsey Hayes iron body combination brake valve (KH89410)that needs a rebuild. Anyone know a supplier that may have rebuild kits?
Parts on the way, thank you
I'm not sure if there are any brass parts in side that.
There probably are.
But be careful with ammonia cleaning of what you THINK may be brass.
I've found anodized aluminum that will fool you.
Not a good thing.
Ask me how I know.
(Either that or the aluminium was discolored by brake fluid.
Not likely.)
Be careful removing metering section. If corroded it is easy to bend the shaft assembly when trying to pull it out. You may also find the check valve (hat) and spring is gone.
