Disc brake conversion
roadrunner69440
12:39 PM
Pa
hi guys, I’m doing a front disc conversion on my 69 runner and have spindles ,brakes , control arms from a 78 Dodge magnum , anyone have experience in making these work, will they work ? Thanks for all your help
If you do the Disco-Tech swap buy the caliper adapters first hardest part to find. MO. They come up for sale here or put a want ad for them. They're usually around $175 here on ebay $300 isn't uncommon asking price.
Edit: I noticed after writing above they give another option for caliper adapters.
I was referring to the pin type adapters.
The knuckles and rotors should work. You'll need to hang the calipers to the rear if you have an anti-sway bar. You can get 11.75 caliper adapters from DoctorDiff and then use a caliper from a rear hung FMJ car. Doctor Diff has the correct brake hose for that setup. In short it is a bolt on swap once you have the correct parts on hand.
