- 1:38 AM
- Nov 21, 2008
- In GTXtacy Illinois
Wonder if the plasticizers used in manufacturing are sourced from overseas.
Is there a mustache in Mexico?
Yeah some questionable manufacturing going on here. Probably cant manufacture them correctly any longer because of epa.Just had the rear blow on the way home from Carlisle 275/60/15 redline that was 2 years old .
The heat ,distance travelled all played a factor in it .
Butttt , my spare also blew that was an unused brand new tire that was sitting in the trunk for
10 years so the story is also check your spares .
Lucky no damage to my car .
Yeah, kinda wondered that myself.Probably cant manufacture them correctly any longer because of epa.
I’ve heard Petroleum jelly works well also for tires sitting aroundalso look at the speed rating of tire. most tires are speed rated for high way. but the knock offs can be different. this will sound funny but use hand lotion on the tires if going to sit for long periods of time. it really helps with the rubber and doesn't allow the dry rot.
Google it , tells exactly how to decodeI know my tire shop says 6 years on trailer tires. Does anyone know how to decipher the numbers to tell the age of a tire? Would be good to know so you don't end up with a new tire that's already 2-3 years old.
Glad you're ok. Do you have classic car insurance? Collision coverage? You can put in a claim for the damage.Just had a good look at my fender...
Worst than I though, tread doing some hard hits. Crumpled the bottom front of the wheel opening some. Bottom rear of the opening, completely caved in, as far as it could go. And, insult to injury, tread 'rode' halfway down the lower part of the door, leaving tire scuff marks.
Will have to pull the fender, for sure. What a frigging bitch.
