FOR SALE Numerous Parts For Sale
Jetblast
8:59 AM
Cincinnati Area
Feedback: 3 / 0 / 0
This is a list of parts I have to sell that I will bring to Columbus or I can ship. I am not a dealer, just cleaning out some parts that I don't plan to use. First of two or more posts.
I have a BB Bellhousing available. It is 69 vintage, 11" clutch and casting ends with 626. Has the ball stud only. $350.
Set of 906 heads. They have been done with a three angle valve job and comes with valves and springs They are disassembled because they have not been lapped. $400.
High Performance Exhaust. Correct for 68/69 and has 280669 and 2843992 casting numbers. $425.
High Performance Exhaust, correct for 1970/71 casting 2899879/2951865 $425.
Clutch style 8.75 rear end. Rebuilt with 3.55 ratio. $625.
Set of Eagle 6.7 connecting rods, brand new. $325
Set of LY rods has new ARP bolts installed. $200.
1966/67 B Body clutch petal set, perfect restore $475.
65 Belvedere Tail light assemblies driver quality $75.00
Steel crank RB engine 20/10 over $275.
Set of 452 heads. Good condition for stock build. $200.
65 Coronet tail lights $100.
65 Coronet right fender, rust in usual place behind wheel well. Otherwise very good condition $250.
65 Coronet Hood. Very good condition $375.
65 Column shift column w/ wheel $100.
65 B Body 833 transmission $425.00
Drive shaft for above $100.
A Body Transmission $425.
Pictures are available on request. All items can be brought to the show in Columbus August 10-11.
What is the a body trans ? An 833 or 904/727???
do you still have the High Performance Exhaust, correct for 1970/71 casting 2899879/2951865 $425
Do you still have the 65 taillights? are the 500 model? Pics would be great if it is the 500. If not do you happen to have a reverse light lens for the 500 taillights?
Thanks, Ken
I some how missed your question about the tail lights I have a set of 500 tail lights that I can send you the pictures of I do not have any extra lenses.
Great. You can either post them here or in a private conversation. If you want to email me let me know and I'll send you a private message. Thanks.
Does the 66/67 pedal set include the belcrank and rod from pedal to belcrank?
what case number on the rear?
