Freshening up my 383 out of my ‘71 RR. I would like to use thin steel head gaskets to raise compression a tad.Motor has stock type KB flat tops with valve reliefs.No cutting ever on block or heads.The stock OEM cam had .450-.458 lift and came with steel gaskets.My cam that was in it with Victor 3464 .042 gaskets .474-.474 lift.I am useing the same cam but would like to use Mopar 4286754 .020 gaskets.See any problem going to the thinner gaskets??? POPS
