Manual shift valve body
Darter6
3:38 PM
Nevada
My memory is getting foggy as of late. I have a A&A forward manual shift valve body 727 trans in a running car that I would like to go back to a stock valve body.The question is,when installing the manual valve body is the governor removed or disabled ? I didn't build the trans and was hoping a racer may have the answer. Thanks in advance !
I usually remove the gov on mine with the manual valve body. Definetly call A & A and check with them. Ron
Just removed manual VB never removed governor. Manual VB's tough on neutral safety switches. Trans ate 2 single pin switches in 12k miles.
Gee never had a neutral safety switch fail. Many, many thousand runs with both 1 pin & 3 pin. Governor is not connected to the neutral start switch.
