FOUND ‘71-‘72 seat belt parts
popslavaz
10:36 PM
Channahon IL.
Feedback: 15 / 0 / 0
I need 1 shoulder strap mounting bolt clam shell cover and 2 fastener bolts. Also 1 shoulder strap when not in use plastic cover and 3 two fastener metal clips with good cover retainer prongs. ThanksPOPS
Pops I have all those pieces I believe in a 72 Charger I am parting yours free just pay postage.. I will check after work tomorrow.
have a bunch of that stuff should have said something when you picked the hood up.
Pops, finally got home and it wasn't dark or RAINING!!! Here is what I pulled let me know what exactly is needed. There is 2 clips per side and one bolt for belt...The 2 clips go in different areas I believe it maybe different from bench seat vs bucket seat but you will need to find out as they screw through the headliner. I check my 2 72'S here both buckets and the one 71 I have here was a bench seat had different longer spacing...Silver metal clips were 1st and the black metal clips were further back..
Brett,The clips pictured will not work for me.The ones I need are all same with two screws per clip.The ones I need are late 70 early 71 so I have been told. The larger single fastener are late 71-72 clips.
Sorry about that they were yours if needed. Let me look to see if I have any others from other cars I parted....
Pops I found one clip with the 2 screws while digging in a box of seat belt parts. It's smaller & shaped different than the 72 set of clips(on right in pics). Don't know why I only have one but it's yours if needed. Let me know.
That will work for me.Do you still have my Address?
Brett,Yes I need the bolts ant the clam covers also. POPS
Ok I will ship out the two shoulder bolts and that one 2 screw cover/retainer with the screws. I only have the one 2 screw "clip cover assembly" so if you need another I can't help you.. It will go out Saturday AM.
Pops, Shipped will be there Tuesday.
