Garys1969RR
My voltmeter shows 16, sometimes * 16.5 volts going to the battery with the engine running. So I checked the field wire voltage at the alternator with the key on, motor not running. The field wire is getting 11.25 volts, with key on and the motor not running. Then I check battery voltage and it is showing 12.25 volts under the same conditions. Is this right? Doesn't the ignition switch feed power to the voltage regulator and the field wire of the alternator from the battery? shouldn't I have the same voltage at the field wire and the battery?
