jogirob
This last weekend I was able to put the finishing touches on my 1978 A904 to 1977 A904 transmission swap on this 1974 Charger. The car feels solid and pulls good. Only problem now is that the speedometer is completely dead. Before dropping the old transmission I had a needle fluttering issue that was fixed by replacing the cable.
About the replacement transmission: I could tell something impacted the output shaft support housing just under the lip of the area where the pinion assembly goes into. I filed off the the imperfection because it was protruding into the mating surface. The rebuilder also got carried away with coarse grey spray paint and some of that paint got onto the mating surface and even on the output shaft where pinion worm gear is. I buffed most of the stuff off with a scotchbrite. I had to tap the pinion assembly in harder than I would've wanted too. No leaks fortunately.
Could I have broken something? If I pull out the pinion assembly will there be a lot of trans fluid to deal with? I did make sure to use the same gear ratio setting as before. I'm dumbfounded as to how simply turning the pinion assembly affects the MPH output by the way.
