69 Charger console wiring harness
INTMD8
6:38 PM
Lake Villa IL
Hello, I'm back for help once again :)
I have the lights and light harness that goes inside the actual console but missing the harness that goes from that to the drivers kick panel.
Mega parts has one for an automatic car and the 4 pin plug matches the one on my console harness but I have a 5 speed manual in the car.
Any reason I would not be able to use this? They don't offer one for a 69 with manual trans.
http://www.megapartsusa.com/proddetail.asp?prod=104-CW108
Thanks!
Don't know if its right for your car. not mine
https://www.ebay.com/itm/1968-1969-...h=item41f2cb4506:g:~1QAAOSweIlb18gT:rk:1:pf:0
Moparnation, he responded I will call today.
Thanks for the link Fran, that's an auto harness as well.
I think I will just get a new manual harness from evans, the difference I'm told is it doesn't have a light for the shift indicator (that an auto car has)
Only 4apd cars had the shift indicator light.......
Thanks!
Brand new member as of 20 minutes ago, I have the exact opposite situation.....I have an intact console, as well as the wire harness that runs from the door sill to the 4 pin connector beneath the seat.... but I do NOT have the light bulbs, housings, and harness to connect from the under seat harness to the console. The folks at Moparforums implied that you "B bodies only" lugnuts are a good bunch of folks....I am looking for any suggestions from the masses.
This?
AT
https://www.ebay.com/itm/68-69-70-C...h=item5917779de7:g:wz0AAOSwuJRb-wG0:rk:1:pf:0
4spd
https://www.ebay.com/itm/NU-COMPLET...=item25fdc37002:g:nCQAAOSwhlZYs53I:rk:30:pf:0
