67 coronet
did mine by myself. used 2 ratchet straps,attached to beams in garage, to hold the doors. worked great.
You can do it with a well placed floor jack and wood blocking.
I've spent my entire life figuring out how to do "two man" jobs with only one man.
Done and done. Learned my lesson from the top pin and reamed well past the pin head. Provided nice footing for my punch as well. Both top and bottom set bushings were oversized and I had to ream out the holes a little more. Which is good, I was worried the bushings were just going to chill in an oblonged hole, that would'nt had lasted long at all. This setup is solid. I also sanded and sprayed the hinges and door with rust converter.Show me a picture of what you are working on and what you have done to it so far. Thanks.
Leo
