Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I have an Offenhauser 360 dual quad intake with two 600 cfm Holley carbs with single feeds and the connector tube to the rear bowls. The carbs have the banjo fittings...my question is will a dual feed line work and fill the rear bowls? SEE THE ABOVE PHOTO I found on the web...it’s hard to see if there is an additional adapter fitting for the line.
If your carbs use the old style o-ring seals upgrade to this type of tube and seal. Tube is different than o-ring tube, no ridge to hold o-ring. This might not be the one for your carb.
not mine https://www.summitracing.com/parts/hly-26-114
Also, I suggest you find one of the "dual feed" fuel lines that is adjustable (or make your own). I doubt if the Holley 600's would be perfectly spaced apart on that intake to match a single-pumper dual feed OR a double-pumper dual feed with exactly the correct distance apart. I think I remember seeing and adjustable dual-feed fuel line that had a small fuel pressure gage in it somewhere.
