What are the U-Shaped parts of the Roadrunner/GTX hood called?
Zell
3:05 AM
Fort Myers, FL
What are these called? The U-shaped component, not the decal that has the '440'. They bolt onto the hood. I've heard people call these 'Call Outs'. Is this the correct term? I need to find replacements for mine.
That would be the term I would say is most often used. That’s wHat I’d call them
I've always called them C scoops. But I've never looked into what they're actually titled.
I 2nd the notion above. Call out is the badge. The backing plate is called an insert
Yep, hood insert....but I'm sure many people have different names, so search under all of the above if you're looking for a set.
Awesome, thanks everyone. I've tried searching for Call Outs and Hood Inserts with mixed results but I'll keep looking.
Much appreciated :)
Power bulge for the hump in the hood?
@kiwigtx I thought the power bulge was the one that could have an air-grabber in middle. I am looking for the inserts for the other type of hood.
Power bulge was probably limited to the '70 model.
@droptop Thanks! I'm looking for the bezels for now. But afterwards, I will be looking for decals.
If I can't find anything in the couple weeks, I'll try and repair mine. One is in good shape and the other is split about 3-4 inches from the end.
