Roadrunner40
I am rebuilding factory distributors and have several cores available and ready to rebuild. This is a small block LA with all factory original parts, I took this down to just housing, walnut blasted housing then every thing is cleaned and checked. Only USA made parts go into this not like the cheap overseas ones mass produced today. Good factory vacuum advance this one has 11 on the arm. Factory original pickup tested, I drill steel collars out in place of plastic ones that break and the shim it for proper end play.
Ready to drop in and run comes with o ring installed and base gasket. I have plenty of cores to rebuild let me know what you need.
$150 Shipped Read Less
Located in Eastern Ohio
