Fuel tank mounting holes missing
Dave532
1:50 PM
MN
My 69 Charger had the trunk and floors replaced. When I went to install the fuel tank I realized there are no holes in the floor for the forward J bolts to hang from. Is this expected with new trunks pans?
If so, does anyone have any location measurements so I can add my own holes?
Thanks,
-Dave
I take it the welded brackets are not there for the J bolts? If so you will have to purchase them and weld them on....
No, I don't see any brackets for the J bolts to hang from if that is what you mean.
The closest bracket would be for the factory upper shock mounts but that wouldn't work or course.
If anyone has a picture of what should be in this location I would be most appreciative.
I did not disassemble this car so I have run into a couple surprises like this.
Thanks,
Have you contacted the dummy that did all that work on your dime X a gizzion??
-Dave
