Roadrunner40
I have a Dana 60 that was built from a truck rear used Dr Diff billet Mopar ends and perches. Was done correctly using fixture pucks and straight bar with caps installed. Measures stock B body 54 1/2 44 on perches. Has 11 inch backing plates brand new 35 spline axles with green bearings installed by Dr diff. Full spool with 5:13 gears and 1350 yoke.
It will need put together and setup has newer bearings also on pinion and spool. I can set it up or you can. I also will put on a pallet and ship through
Fastenal. Power lock in pic not included that’s for mine
$1200 OBO
Located in Eastern Ohio
$1200 OBO
