FOUND Big Block 727 dipstick and tube
Hotrod20
9:30 AM
Plymouth MI
Feedback: 36 / 0 / 0
Looking for a clean and original undamaged trans fluid dipstick and dipstick tube for a big block 727.
Not interested in aftermarket parts. Factory parts only please.
Thank you
HotRod20
What year? There are different angles!
Thank you
HotRod20
I have a tube ,no stick, if that helps $15 shipped,
I don't know the year
If they are factory, do they have a part # on them? I have a tube and stick out of my 66 Sat 727.
A 65 and up will work So you shouldn't have a problem 63-64 tubes were more straight up behind the head for ex. manifold clearance, some pointed more to the inner fender panel and were attached to the trans case pan rail and bell housing bolt!
If you can come up with they look like or a pic I have 2 diff types. Have no idea what they are for. If I have one you can use just pay shipping.
Its for a 69 roadrunner, 440 / 727 transplant.
HotRod20
69 tube sits between exhaust manifold and shock tower. '70 goes between rocker cover and manifold.
Awesome picture, but...I need the "Transmission Dipstick and Tube" (Not the engine Oil dipstick) for a 69 B Body 440 / 727 transplant.
Rick Allison at A&A Transmissions has a nice reproduction of the tube and dipstick. Runs between $45 and $65 depending upon which style you go with.
Thanks everyone, I also found a new made in U.S.A. reproduction set at Classic Industries for $74.99 for the tube,dipstick and o ring. decisions...decisions.. guess I'll go new instead of used. :)
HotRod20
