FOUND 1970 column shift linkage needed
91r/t
4:21 PM
Buffalo, NY
Feedback: 7 / 0 / 0
I an in need of a piece for my buddies 1970 column shift linkage on his 70 coronet. It is the small lever on the right that goes from the cross shaft to the shift lever on the trans. Let me know what you guys got. I would buy the whole linkage if its all I can find. Thanks in advance. Pic below shows the whole deal but I only need the smaller lever on the right on the assembly.
address to send it to? I got you covered...you talking about the little L shaped bracket, or the 6" long linkage arm?
6" arm. Goes from that cross shaft to the shift lever on trans.
