FJ6 v code RR
I have a fresh 1978 440 bolt in ready with c body oil pan will fit in a-body and b-e-body cars, new plugs, wires, cap rotor, alternator, water pump and valve covers also new Edelbrock aluminum intake. 440 has flat top pistons 9.5 to 1 and stock bore 4.32 and std/std cast crank and a 443 Lift/288 duration cam 452 hardened seat heads stock valves will run on 87-93 pump gas. This will be nice with procharger on it or the way it is. This is ready for your car or truck or what ever you want to put it in. If you have any questions please ask. $4500
*** I DO HAVE A VIDEO OF THIS ENGINE RUNNING ON A RUN ENGINE STAND. *** *** The 440 is on a run stand so you can here it run before you buy if you like.***
I also have 1966-74 b/e body big block motor mounts and b/e body headers and new in box B&M flexplate for extra money.
