68Moparmaniac
Anyone have feed back on the Caltrac setup? Is it worth it or just a black hole for money?
good luck 68. And I also agree with Biomed above.It tells me that they get the job done, on fast cars.Virtually ALL leaf spring cars that run NHRA Stock Eliminator use CalTracs. What does that tell you?
Speaking of Dana 60s, pinion snubber, and traction...Dana 60 and don’t have any way to use a pinion snubber. Gotta have something to aid in traction.
Or...get the 4 link dialed in and be done with it...The Key is getting the correct spring rate, using solid spring perch bushings and setting up your Pinion Snubber AND Pinion Angle correctly. It is also important to have the springs freshened every 3 years
Stocker, Super Stockers and NSS Cars not allowed 4 Links.Or...get the 4 link dialed in and be done with it...
Yes sir, I know.Stocker, Super Stockers and NSS Cars not allowed 4 Links.![]()
