Disc brake conversion question
dan juhasz
12:11 AM
Whiting NJ
bought a disc brake conversion from leed brakes for the 66 Hemi coronet. Is it advisable to tee the PCv hose to supply the booster? The afb’s have no large vacuum nipples and the intake has no other vacuum source that I can see. What do you think?
Dan
I read or heard somewhere not to run PVC and booster to the same vacuum source.
I don't like the idea , I just wonder how it was done on a car originally equipped with power brakes
Did cars originally equipped with power brakes have a different carb that had a nipple provision for pcv so the manifold provision could be used for the booster?
I don’t know about Hemi intakes but my 440 has a pipe thread tap into a runner behind the carb. Then a nipple out of that.
Something like this.
I have a 66 Street Hemi in my 67 Coronet. My booster vacuum line
is on port directly on intake rear.
Generally I believe PCV is under the carb so a few cylinders get there share of the gunk the PCV draws in to the engine. If you have it on a leg of the manifold that goes to one cylinder that cylinder can oil up.
As the other guys have posted the power brake comes from one side of the intake.
Are you sure the manifold does not have a port and you missed it?
Most cars that could have power brakes would have the port.
Hard to imagine they would bother having two separate intake manifolds.
I ended up removing the primary carb, removed what appeared to be a 3/8 core valley plug that was pressed in , tapped it out for a brass nipple and used this for pcv. I used the manifold tap for the booster.
