Turbocharger
coronet4406
2:27 AM
bellefontaine
What's a good single turbocharger for a 318 I could stick into a 75 sports fury and not brake the bank
you might want to start with a turbo small block gm I think both olds and pontiac
Look up On3 Performance, they’ve got T4’s in a 61mm or 70mm for a tick over $300. They’ve also got some 76mm stuff if you really want to send the rods through the pan...
I forgot to put the word kit a complete kit for single turbo for small block mopar most I find are twin turbos and not many places selling turbo kits for mopar
Yeah... that changes everything. I don’t think anyone is ever going to chase that market. The demand is probably next to nothing. You’re gonna have to find a shop that does custom work and have them do it.
or adapt one of the 300ish inch factory engineered units I suggested
why not a supercharger?
https://www.jegs.com/i/Paxton/769/1...UF79AqzRtTeqFV4-RRtWaeH1VogiIuJ0aAmH-EALw_wcB
Paxton NOVI 1200 Tuner Supercharger System Small Block Mopar
Part Number: 769-1201850P
made_in_usa.svg
Ebay has " complete" kits, but I would be skeptical of them, probably better piecing your own kit together, and you also have the fueling to add to it. You will have to do some fabrication most likely anyway. I did see 318 twin turbo headers listed as well, they could last a couple years without cracking too much if you support your turbos.How much power does your 318 make now? How much hp do you want to make? A single plumbed into stock exhaust manifolds could lessen the fab work.
