superbeedave
Hi guy's, I just replaced tires on my 69 Bee from P235/60-15 on all four wheels to fronts P225/70-15 and rears are now P235/70-15. The prior tires were 26.1 inches tall and now my new front ones are 27.4 and back ones are 28.0. After I went for my first test drive before making any kind of front end height adjustments I found the car was sort of wandering some s o I came home and adjusted the front end down to 1 5/8 and side to side difference is dead on. my measurement from ground to middle of wheel well opening is now 25 7/8 front and 27 1/8 back. After doing this car seems better but do I need a new alignment after going to taller tires? Car drives straight on the highway it just wanders some meaning I'm every so often turning the wheel a little to straighten back up. So what would be affected most by going to taller tires would it be the camber or caster? Thank you! Dave
