Mike Gaines
- 4:39 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I am going to have a new motor built for my 65 Belvedere.
I want it to run in the B/Gas class here at my tracks in California.
That class is 8.60.
I checked with Wallace Racing Calculators and it looks like I will need 950HP at my 3100lb weight (with driver) to get to that ET.
I know I will for sure need a block with 4 bolt mains to handle that HP.
The ignition/carb/intake/headers are pretty straight forward but it is the following I am asking on input for:
1) Camshaft / Lifters / Pushrods / Springs
2) Rocker Arms / Shafts
3) Compression Ratio
4) Oiling System.
5) Rods
INDY has their 572 "Bracket Master" listed at 930HP for $22k
a) 572" 4 Bolt Iron Block
b) Aluminum Rods
c) 572-13 CNC 385 Heads
d) Jesel 1.7 Rockers
e) Roller Cam with 284/300 @.050 with .816/.765 lift with the 1.7 rockers.
f) 1150 Dominator with their tall intake.
Is this the route to take ?
Does INDY still supply iron 4 bolt blocks or do they only have aluminum 4 bolt blocks.
The Aluminum block is $3k extra.
Buy it from INDY or have someone else build it ?
Your thoughts....
I know I can get my tranny from A&A or Cope and my Converter from Lenny at Ultimate Converters.
That class is 8.60.
4) Oiling System.
5) Rods
b) Aluminum Rods
Your thoughts....
