Oil sending unit connector
velrob
8:52 AM
toronto
Can anyone let me know what sort of connector is used on this oil temperature unit?
You mean a spade terminal? I tried that it seems kinda easy to fall off
I guess I'll try another spade terminal and close the gap a bit so it's tighter
I'll just cut one of my old connectors like the ebay connector
:) We know what you referring to, but it's the oil pressure sending unit, not oil temperature. All the advice is great. :)
Depends how Correct you want to bee ?
It doesn’t have the click in release tab like the picture above with the plastic connector
However it does have a small tab on the end where it slides over the sender to keep it from coming loose or backing off
http://www.evanswiring.com/default.htm
They might sell the individual connector
Correct , click on picture
im not looking for super correct rofl. this car is for myself to drive. alot on the car is not correct :)
plus i have extra connectors from my old harness with the black terminal at the end that ill modify
