- 10:36 AM
- Feb 20, 2012
- New Hampster
With a clean undented reservoir.
Thanks!
Thanks!
what year application, ie PS return hose nipple size.??
I have both
The return line is around 1/2" not 11/32" or 3/8". My 66 Satellites PS is the larger size.RC you just contradicted yourself here. You specified TRW and that is what MOPAR John says he has. It sure as hell looks the same as the one you are in need of. You get confused on the difference? By the way I have both along with complete rebuild gasket kits and replacement reservoirs for it...cr8crshr/Bill![]()
OOOHHHH!!! OK...I missed that RC. Sorry for my mistake but I didn't look at that particular point and focused on the rear of the reservoir instead...Carry one...cr8crshr/BillThe return hose nipple is in a different location & different diameter. I believe the one John has is an earlier model.
I had a friend just go through this whole power steering pump issue. Pulleys were different between engines and whether or not you had A/C when the engine came with a TRW pump. Worst part about this is the TRW pump does not have the provisions to remove the pulley without completely disassembling the pump. head over to mymopar.com and go to their reference section. There they have the parts manuals covering a lot of the years this site covers and make sure what ever you get will work for your application so your not chasing your tail!
