WTB Alternator brackets
EccentricMagpies
1:58 AM
Wisconsin
Feedback: 1 / 0 / 0
Need the all mounting brackets for alternator:
Application:
360 (not sure if all small blocks have same brackets)
Non-AC car
Application:
Non-AC car
Here’s a pic
that's the piece i have (if i wanted to install the AC unit)
I have Magnum heads on now and I had to cut and weld the old piece and it caused other alignment issues after that... that is why i need non-AC
I'll include photo's
three pieces with non-AC.
you have the piece to tighten the belt which is mounted below the triangle piece. Then I suppose some spacer on the area it mounts on the head.
wait.. maybe i can simply cut that mount to the head off and then if i can get this triangle piece and the spacer to meet the block i might be set.
The spacer (Tube) should be avaliable at your local parts store. It’s a cut to fit universal. I’ve bought a couple over the years. The triangle piece was available in chrome but I haven’t bought one of those in years. The last one I bought was from Proform. If I remember correctly it was staggered & I had to use washers to get the alignment right.
