- 5:07 PM
- Jul 1, 2015
JP,o.k. thank you all for the advise.
one more question coming. I am running the Eddy 750 on this 30 over 440 with a 484/284 cam and have run this fuel pump for years. Would you suggest using the Eddy fuel pump that flow 110 gph at 6psi max or the Carter that flow 120 gph but has a range of 6.9-9.5?
I definately dont want too much pressure, just volume. Carter has a super street pump that is rated at 120 gpm at 5.5-6.5 but I see no listing for use with a 440.
The Carter pump you mentioned has a 120 GPM @ 7 PSI (nomimal). Do you REALLY mean 120 GPH at the same pressure?
I would suggest the Edlebrock (aka "Eddy") pump at the advertised rating (your numbers) of 110 GPH @ 6 PSI will be more than sufficient OR a stock Carter replacement for your application.
FYI...I use a stock Carter pump for my RS23V0A******* GTX, an origional six barrel engine with the Crane equal to the Mopar 292° 0.509" lift cam. I've not have had a fuel VOLUME issue feeding 1350 CFMs of Holley carbs at wide open throttle the end of a 1/4 mile contest even with with 4.10:1 Dana 60 gears at 6500 RPM.
Just my opinion of course. Others will have their own opinions and preferences.
Bob Renton
