Help identify?
madmopar
9:49 AM
So Cal
Trying to save my original dssh harness. I'm replacing the bulkhead connector for sure as it looked pretty bad. The rest stll looks decent except for a few hacks that I think were the result of some sort of alarm and aftermaket radio. I had labeled everything when I took it apart but unfortunately its beeen about a decade and the label had faded. These two connectors need replacing for sure, the melted one I think was plugged into the heater/ ac control switch. I dont recall were the cracked gray connector was from. Any ideas on where to find? Btw its a 68 charger with rallye gauges.
20190802_200323.jpg 20190802_200201.jpg 20190802_200155.jpg 20190810_110656.jpg
First pic is the dimmer connector for foot dimmer.
3rd pic is the connector for the rear harness for tail lights and back up lights in the driver side kick panel.
I have a set of old ones that look better than yours. I have 2 66 harnesses one is cut up pretty bad. I can remove them for you. Pretty sure those 2 items didnt change much in 2 years time.
Not sure where to locate new ones.
That's awesome thank you. I swapped out bulkheads last night and one of the terminals broke off. It was a black wire near the center, slightly larger gauge the the rest. Most of the bulkhead was brittle and burnt around there.
You should start a wanted ad.
I will check on the bulkhead connector as well. But be warned. That was always a hot spot on these old cars. I got busy today had to run to the airport to pick up my kid.
I will post some pictures of the stuff I have.
C2CFA29E-6818-4C31-8F4F-BD306C969808.jpeg 95598426-8ED7-438F-ADFF-447DE362D9DE.jpeg
Here is a repop od the bulkhead connector.
https://www.classicindustries.com/p...MIta7PnL_74wIVSJyzCh1VGAYOEAkYASABEgJNu_D_BwE
And for broken or burnt wires you will need these to fix anthing cooked at the bulkhead connector.
https://www.ebay.com/itm/Mopar-Male...s-Terminal-Crimp-Connectors-NOS-/192502001151
Please allow me to jump in with a question: I had thought about installing a new BH; but have never come across this part being available unless getting a complete wiring harness. Is this the case? Thanks
Found a bh connector on ebay, came with two of the male connectors ( banks 2&3 I think) also for about $80. If I use one of the above mentioned female terminals in the bh will I need swap the male terminal also? Or will it work with the existing terminal?
If its bad on the bulkhead side I would check the under hood side and replace if cooked..
