Comp Cams dowel pin
roadrunnerh
4:07 AM
Pittsburgh, PA
My new Summit timing chain set (Cam gear) will fit on my original cam and the dowel is flush with the face of the gear. On this new Comp Cams cam, the dowel on the cam protrudes above the face of the cam gear - I can not tighten the cam bolt, washer interferes. WTF?
Anyone experience this?
take a brass hammer to tap on the pin to make sure it is bottomed out in the hole then grind it down to just below the hole. or call the cam maker and ask them.
