Crackedback
There are people that have a lot of experience, some just don't build stuff for a living.
Here's a little tidbit I found with a quick search, same general build as yours using the trick flow 270's on a 10.5:1 engine. I think it is beyond your expectations even with that crummy 9-9.5:1 compression.
https://static.trickflow.com/global/images/chartsguides/t/tfs-61617801-c01_wj.pdf
Depending on where the 906's cc, normally in the high 80's, the TF270 is at 78 to start. So it would give you a potential compression bump right there.
