New member seeking some help
Owlcrow
1:34 AM
Milwaukee
Hi I am the owner of a 73 roadrunner. The car is pretty decent has a 440 and body is relatively nice. I have been having a problem with the drivers side door however. I need to locate a latch assembly as well as a new exterior handle. I broke it off the other day the latch was taken out and one of the parts was snapped tack welded and I have not looked yet but imagine the weld snapped. I went to open the door the door did not open I gave it a tug and ended up snapping the left side of the outer handle and it dangles now.
Anyhow I am hoping someone knows where to find these parts I have been searching with no luck at all.
Thanks in advance
here is a pic of the car
Door handles are easy to find, available from the major parts places, but Jeff at 521 restorations is a good source and a member here. Here is the link.
http://www.521restorations.com/index.pl?page=bbody&sub1=Door Handles
Regarding the latch assembly, you will most likely have to source it used. I had to replace one on my car last year and found a used one, so check the classified section here and of course ebay.
Welcome from the show me state!!
Welcome.
Don't forget the door hinges. Worn/sagging hinges are most likely the root cause of your latch/handle issue.
Welcome aboard from NJ. Very nice 73 you have there, Best of luck with it. By the way. I'm a Packer fan!
:thumbsup:
Thanks for the information I may have a local lead but if that falls through I will definitely look into provided info
Those are the handles. I was thinking on getting a used one from a local source (if they come through) however both of my handles are painted so I could live with a pair of chrome or black handles that match. I am pondering painting the handle or having it done.
This helps by giving me another way to think about doing the job. I hate the broken door thing.....
thanks to all for the welcoming replies I am glad I joined this forum it seems like a great group of people
welcome to FBBO
Welcome.
Glad you decided to join the group.
