- 4:26 PM
- Mar 28, 2014
- South Louisiana
The 3.54s in my Dana 60 440+6 70 Roadrunner worked fine as a compromise gear ratio. 3,500 RPM at 70, just tolerable, but also allowed for a shift into 4th gear far enough before the 1320 line to make it workable.has 4.10 gears
BUT
Once I installed the OD Passon Performance a855 5 speed, I simultaneously switched to 4.10 gears in the Dana 60.
WOW!
1st gear still quite useable, 5th gear at 70 I'm down to 2,750 RPMs which is a LOT better than the 750 less RPMs may indicate. BIG difference in reduction of noise and much more peace of mind regarding wear and tear.
I am much more focused on drag strip performance than highway or road course top speed. I can still cover 1320 feet in 1st-4th, and the 4.10 makes it a lot more fun!
If I had a Superbird or Daytona, I would have kept the 3.54
