- 10:48 AM
- Aug 5, 2011
- Lisle, HELLinois!
For your consideration is a brand new B&M Clutch-Flite complete setup. The transmission has never been used, just bolted up with the pieces to make sure everything would fit. It comes with a Lakewood Scattershield and block saver, E&R Borg & Beck style pressure plate, Metallic
clutch disc, and an E&R 80lb. Billet flywheel. The rotating assembly was balanced by E&R!Complete clutch pedal and brake pedal assembly out of a 1968 Roadrunner. This is NOT a kit, This is a 100% B&M Transmission.
Again, there is no wear on any of the parts! Throw-out bearing and fork also. I have a Z-Bar
but I need to find it! It was engineered for a 1968 B-Body weighing approx. 3850lbs. with a
440 and 4:10 Dana. Don't really want to ship this so, pick-up only in Lisle, Illinois.
$4500.00 sounds fair to me! Thank you!
