inner doors plastic water shields
moparjohnny
6:10 PM
ga
anyone knows who sells those? thanks
Just make them, very easy to do: You can even by the glue/tape at HOme Depost or Lowes for the factory look.
I made mine this weekend out of the plastic that a mattress was wrapped in, based off a post I found here. I also used butyl caulk as the adhesive, don't do that. Go find butyl tape or rope, holy crap was caulk a mess.
Ya the dum dum works well. Easy clean up if required. Doesnt smear all over like all other stuff and its a clean result.
I have a complete set that I need to get rid of. CHEAPLY!!! Just want the set gone!!! Pm me if you have an interest and we can discuss it. Again, not wanting a lot of $$$'s...cr8crshr/Bill:thumbsup::thumbsup::thumbsup::usflag::usflag::usflag:
yeah, ill be surprised if my door panels aren't glued on as a result of this flop. lmao!
You don't need a whole ribbon of dum-dum. Just some small balls of it spaced around the door about every 6 ", and press your plastic into it with your thumb. Easy to take off if you ever need to............MO
Draft seal cord is available at most hardware stores for just a few dollars. The whole idea is to make the area water proof from leakage through the glass seals/felts and condensation so it doesn't get to the door panel backings. You want it sealed tight on THREE sides and tucked into the slot at the bottom and taped so any water intrusion runs into the rockers.
But on E bodies the door panels are plastic....and they are junk.
They were still using the same stuff in 92.....still junk.
