Paul Secoy
Then you have everything you need to determine 0.050" if you want.
I assume you mean when it returns and I get it installed with a degree wheel on it, as I can't seem to get there with the current info, lol.
Example for .050
241+241= 482
482/4=120.5
120.5-112=8.5
8.5x2=17
17 degrees should be the overlap at .050.
A 400 B engine with the parts you listed seems to me to be one of the best inherent engines as far as geometry goes for adding boost.
Adding cubic inches is, as you said, not important because it's going to behave like a much larger displacement engine, and with the big bore and short stroke, along with forced induction, well it's going to be quite the mill.
There are turbo specific grinds, but that cam should suit you well, and with a turbo engine, if you want more power, add more boost!![]()
Dwayne Porter is a name that comes up often, along with Racer Brown and Hughes.Well, after some research of proven turbo cam designs, 17 degrees of overlap seems like a bit much. The ones I found that I know work well are in the 2 to 2.5 degree range, quite a bit off my old 528, so I guess it stays on the shelf.
Crower has a .511 solid with a wide 112 degree LSA, that works out to 2 degrees of overlap. I think I will try this one first.
Thanks to all that helped me
Uh .050 is useful mostly for setting timing
for comparing cams it can get you way off
depending on the "intensity" the difference between .004 or .006 and .050
which can be different on the intake and exhaust lobe
and different on the opening and closing ramps
you can contact dart19666 at Crower or some of the above
If thinking of a solid or roller contact Mike Jones on your short list
I guess my turbo cam fails your overlap qualificationWell, after some research of proven turbo cam designs, 17 degrees of overlap seems like a bit much. The ones I found that I know work well are in the 2 to 2.5 degree range, quite a bit off my old 528, so I guess it stays on the shelf.
Clearly you don't know what you're doing.....![]()
I have not yet run it. We still have to wire the EFI. I think somehow you may have gotten fixated on one parameter of a complex puzzle. These engines are still operating on a pressure differential, just a different version of it than an NA engine. Scavenging isn’t such a concern as you have manifold pressure to fill a cylinder so overlap is less critical. Once opening and closing points are then determined, overlap and lsa are merely fallouts of the numbers. You can manipulate those points to affect turbo spool or in my case crutch the rather smallish 75mm turbines hence the exhaust duration. I’m also running non-intercooled so power will be fuel limited. We’ve made 1635Hp from a Procharged SBF and have gone 8.0@170 with a Y2K on a yates headed 361sbf so I have some experience with forced induction combos.Have you run this combo? I am actually curious, not being a dick.. I ask because a friend has a Gen 3 392 hemi with a little smaller cam, I have his cam card, and his does land at 2 degrees ovelap, just like the very well respected Brian Tooley stage 2 turbo cam. My friends car makes 1,300 HP, and I saw him run an 8.1 at 178 this year, so I guess it works.
The 528 cam will have similar valve overlap timing as the TBR Stage II cams
They take curves like they're on rails!
