SOLD 1966 Belvedere II 4 door
Moparbrad
12:25 PM
Phoenix, AZ
Feedback: +4 / =0 / -0
I’m going to be drilling this car apart as there really isn’t much more to unbolt. There is some rust in the lower right quarter but the wheel well arch is nice. Driver side quarter is really nice, no rust. Also the passenger side floors are gone. Driver side is good. Below are some prices, if you don’t see it please inquire.
-a/c fire wall $100
-inner front fenders $100 ea
-core support $150
-trunk floor spare tire well $100
-V8 K member $150
-cowl assembly $250
-Passenger side rear quarter wheel arch $100
-driver side quarter $250
Please inquire if you don’t see it listed
Located in Phoenix Arizona.
004BC153-A65A-474E-9868-4A6A47E97579.jpeg ADA8D871-07F9-445B-8ACF-C8B221DF83BC.jpeg E2DFB28B-D6C4-4F3B-938C-D11C5DF7DD5E.jpeg C942E9C6-D2D1-4477-A5B3-6D91884B4419.jpeg 8EDD9C8B-F3E8-40FB-8464-87F6221ED01B.jpeg 64D8B2A4-DB4C-4EEA-B02E-BEA888196874.jpeg C32C94D6-2006-41AE-B51A-6AF341913CB6.jpeg AF5B09F6-4884-4143-AB6A-8C1CDDD29495.jpeg FDFEF0F1-E451-4238-A5DE-4E5B3F5D2234.jpeg D48B59E2-9D80-4A51-AECB-66B3C0615846.jpeg
i would be interested in the rear crossmember, its the piece that ties the rear frame rails together and its also the piece that the bumper bolts to.... also i would be interested in the the trunk gutters assuming that they are rust free... i would be useing these to restore a 67 GTX... I think that they are interchangeable ... im located in CT.....
Sheet metal from the torsion bar cross member forward is SOLD! That’s the front rails, inners, core support, fire wall and cowl
Still have the suspension and K member.
-Rear wheel tubs $150 each
-Rear trunk floor drop offs $100 each
-dash harness $100 shipped
-power steering column shift auto column $100
The car has been pretty cut up and drilled apart now. So basically there are only a few things left:
-rear frame rails $100 each
-rear shock cross member $50
-both rear wheel tubs $150 each
-passenger side trunk floor drop off $100
-driver side tail light panel $40
-k member with steering link and p/s box $100
