FOR SALE 1975 roadrunner / 78 monaco parts /shell
Johnny Mac
FBBO Vendor
FBBO Sponsor
3:38 AM
NE OHIO
Posting for sale, just in case someone can use this before I post it as a Derby / dirt car shell...As it IS a "real" roadrunner with a R dash. Vin still on it. NO TITLE. Pretty rough. Would be a tall task to put back on the street ever...maybe a drag shell...
2 weeks before I cut it up and scrap it.
Take whatever is left as it's parted out for $300.
As a shell. you will need a flatbed.
The roof is in very good shape.
Back and side door glass is good
No windshield
I will sell side glass for $75 a window. 125 for both.
I won't remove back glass. So consider it going with the shell.
If you are local, you can hand me $100 then try and take it out yourself.
Anything below is for sale
Has a big block k frame from what I can tell.
Solid Frame rails
front brakes are pending pickup.
Complete 8.25 drum to drum. With leafs Was just on the road. $250.
The parts below are what I have accumulated from a 75 RR. A 78 2 door monaco, and other mopars.
11 inch drums. These look like they were just serviced. Pads look new. 2.5 wide.
$200
White seats are pending pickup.
$150 for the red ones.
Washer and overflow bottles. $20 ea
B BATTERY tray. $20
Smaller drums. Complete off 8.75. $200.
Blue steering Colum. $100
Tuff wheel? $75
Complete monaco, or roadrunner header panel. (Have both) $180
1 PS box 75
1PS box with pump, lines, pitman, $150
SB manifolds. $40
Radiator shroud, fan $75.
All the front pulleys from the AC setup. $50
Complete A/c compressor and hoses etc. 75
Monaco taillights and extensions $75
I'm keeping most exterior trim.
Make offers on anything else pictured via PM. Everything is OBO.
20191215_181804.jpg 20191215_182119.jpg 20191215_181925.jpg 20191215_181832.jpg 20191208_163702.jpg 20191215_181809.jpg 20191215_181712.jpg 20191215_182137.jpg 20191215_181629.jpg 20191215_182127.jpg
More pics...sorry out of order. 11 inch drums is complete kit. With backing plates. Drums, etc. Ready to bolt on.
Same with the other smaller ones. Complete
20191215_181804.jpg 20191215_181712.jpg 20191215_181629.jpg 20191215_181609.jpg 20191215_181603.jpg 20191215_181735.jpg 20191215_181729.jpg
just an FYI, my plan is to strip this thing this weekend, and send the shell over the scales. if noone wants it, or anything off it, i'm cutting the roof off. and scrapping the rest.
YES! the black one has the full disc brake setup in tact. Complete K frame is in it. sorry i didn't see this earlier.
I really wish I was closer, I hate to see that RoadRunner go to the crusher. I know they aren't as popular, but that grill assembly has to worth it to someone.
If you have the brakes, any chance that they are the 11.75 disks? The caliper brackets are very valuable if they are the pin-style.
I hope you get some more interest in the parts! Hate to see anything go to scrap, but I know sometimes that's the last option.
It's been pouring rain here for a few days so haven't walked out to check the brakes. What makes the calipers brackets valuable? I assumed they were the same as my 78 monaco
The entire setup is what you need to upgrade 70-72 B-body, and 70-74 E-bodies to the 11.75" brakes. Link to great write up on what you need: https://www.allpar.com/history/mopar/brakes/disc-main.html
However, the hardest part to find is the caliper brackets to go to the big brakes. The slider type are more common, but the pin-style are preferred and much harder to find. Yes, the 76-79 Monoco/Cordoba, etc that have a big block, likely has this setup, but it's not a given.
@cbodybob they look solid to me. Door swings nice. Don't know what you are replacing though. Hard to photograph a hinge.
@rumblefish360 There are some pics of the floor above. unfortunately probably not worth cutting out.
same for the trunk. probably only good for some small patches. i know it has some holes by the frame rails.
Best way to check them is open door all the way & grab the end of the door & see if it hinge moves as you shake the door up & down. If you can move the door up & down the hinge is bad.
I'm gonna assume they aren't what you are looking for. There is a little play with the door open.
How much do you want. I might can rebuild them.
55 shipped? Driver side pair? I only say that bc FedEx hammered me my last small shipment.
And Idk how hard or easy They will come off
Let me check mine. I think it’s just one hinge that’s bad. Get back soon
Ok I checked mine & only the driver side upper is bad. Can you check yours & give a price shipped to 27596 in NC
