66plysat
- 7:04 AM
- Feb 11, 2010
- Rancho Cucamonga, Ca.
Sounds great, thanks!!! FBBO is a great resource for us Mopar guys!I have a 66 Ply Sat myself and lots of clips. I will check my stash and get back to you. If I do have them, then no charge as the worth of them to me is to help out a fellow 66 Sat owner...cr8crshr/Bill![]()
Still looking but I think I know where they are. In the car's trunk and it is sleeping away tucked in for the Winter. Back later today with my search results...cr8crshr/BillSounds great, thanks!!! FBBO is a great resource for us Mopar guys!
Wondering how many for whole car? My parts book seems to say 8, 2 for front fenders 4 for doors and 2 on quarters. Or is it 16 for whole car? It has been 38 years since mine have been off. Those are the only trim fasteners I didn't order.I need 6 of the fasteners that hold the top fender trim on a 66 Satellite. I'm looking for the hard plastic fasteners that have the screw post attatched. Any help that can be provided will be appreciated.
View attachment 892415 View attachment 892416 View attachment 892417
Thanks for looking, I'm going to try to modify a couple of the plastic pin types and add a nut and bolt to hold them securely. I tried to use them to replace the old ones and they didn't seat correctly so when I attached the trim they dented the trim because they sat a little too high. Gotta love Mopar replacement pieces, usually don't fit quite right if you can find a replacement at all! Again thanks for your help.Well I only have the plastic pin types for the trim and not the 8 screw type ones. Sorry I cannot help you out there but if you have any other needs for parts, let me know as a I have a ton for the 66 Ply Sat...cr8crshr/Bill![]()
That's exactly what I did with the white pin style fastener. I drilled out the center and replaced the plastic pin with a small bolt, then fastened the trim with a nut on the underside of the fender, it worked well. Thanks for your offer but I was able to reuse the fasteners that I had.This is what I have left around...I wonder if you could widdle out the plastic a little and use a counter sunk bolt in the white plastic ones to act like the black ones you have...if any of this would help you they are yours...just let me know. Got a few of the springy ones too.
