How Could Mopar Vinyl Top Cars NOT Have Been Painted?
Dibbons
4:39 PM
La Paz, B.C.S., Mexico
if I am not mistaken, both our full and canopy vinyl top classic muscle cars are all rusty under the vinyl top. My question is how was that even possible, I can't picture the factory painting a car with the vinyl top already in place. What am I missing here? Thank you.
Photo is my '72 SSP with canopy vinyl roof removed (it's rusty under there).
Vinyl tops are porous....water gets through eventually, and sits there festering away for years unchecked.
Maybe this will help answer that question. When I removed the original vinyl top to be replaced I saw that the car was only painted body color past the areas that the top would be covering. The rest of the roof was gray primer only. If it was known to the painters that a particular car would receive a vinyl top, it wouldn't make much sense to have the top of the car receive the same attention as the body if it was going to be hidden anyway. Primer? Not the greatest rust prevention.
Only primer on top, body colour by the guy in the "booth" only far enough up to make sure he had it covered. No point in wasting paint when it was only 50 cents a gallon! LOL
Exactly. :thankyou:
Furthermore....it is likely that there will be more rust marks underneath the area where the stitching is...as water can get through there easier. And it more likely there is an air gap under that stitching for rust to grow.
Bearing in mind that Chrysler never meant for these cars to last 50 years. Leaving primer under a vinyl top typically, would have lasted the expected life of the vehicle.
Precisely. :thumbsup:
These cars were never intended to outlive the guys who built them. :rolleyes:
My '70 Charger after I stripped off the rest of the shredded vinyl:
My 72 had the vinyl top. The car had many pin holes rusted thru. Hard to fix. They came back as I didn't replace the top,just paint after a few years.
Talked to a guy that worked at the Twinsburg Ohio stamping plant said if a roof panel had defects was marked for vinyl top install.
By brother worked at the STL plant for a while around 1970. Anything that got roof damage, even if the car was being built to order got a vinyl roof. And if it was already on order the vinyl was gratis.
