440 6-pack fitment under a 67 Belvedere hood
hm427donzi
4:50 AM
Kingston, TN
Is there any clearance problems with installing a six pack under a stock 1967 Belvedere hood? I would like to use the stock six pack air cleaner. Thanks!
Not sure, I think my OEM 69 1/2 air cleaner assembly fit under my '65 Coronet hood, the intake & carbs did. The '70 & latter setups had more of a drop base which would give better clearance.
That's one I haven't tried, but it fits under my 68 Dart GTS hood just fine.
My 67 factory original 440 Magnum Charger air cleaner left an impression in the hood pad. The 6 pack carb and air cleaner fit with no issue. Conclusion, if the 440 Magnum, or 440 Super Cammando was an option in your 67, the 6 pack set up will fit.
It should be fine. Fits under my stock 70 Charger hood but my Cali emissions hood insulation does rub on the air cleaner lid so it is close on any B Body inner hood structure.
That's one I haven't tried, but it fits under my 68 Dart GTS hood just fine. View attachment 919804
From the photo, it looks like it fits well below the hood. I'll bet that thing goes like hell. Barracudas must fit the same. What others have you tried? I have tried 70RR and 1966 Chrysler, they fit. I assume all '68 and beyond fit. I wonder about the early B's, they appear to have tall engine bays. I'm 400 miles from civilization and never get to see 6 pack conversions in car shows, so I wonder which ones can work.
