Gearhead72
I'm evaluating the body of my 72 SE charger to see if it's worth restoration or a resto mod project. I have had it since I was 16 I'm now almost 47.
The car has been sitting outside since 1996. I'm looking over the rust issues and find most problem areas are typically and sheet metal is available except for the drive door jamb. The panel that holds the door switch for the dome light. Does anyone know of a source for this metal.
Also I found that the smaller window of the SE has a filler panel Bondoed in. It appears factor but sketchy. I can't believe dodge would build it this way. The mud is almost 1/2" thick . Has anyone seen this before?
