2 vs 3 Speed Wiper Motor
dodge68charger
3:44 PM
Washington
I Read That The 2 Speed And 3 Speed Wiper Motors Had Different Linkages. How Do I Go About Telling What Type Of Wiper Motor Linkages I Have?
I Liked The Look Of a 3 Speed So I Got One Rebuilt. When I Put It On The Car and Wired It I Can Hear The Motor Still Pulsating When The Switch Is Off.
I Did Change To a 3 Speed Switch. Car Is a 1968 Charger
Thank You
The only linkage parts different from 2 speed to 3 speed are the crank arm and bushing.the crank arm you need is part# 2822 273 if I’m remembering correctly.
the crank arm bushing is white and you will need a 3 speed switch.
What about wiring any difference?
It’s been a while since I did the swap but seems like just a jumper on the switch. I will look at the schematic and see if it will jog my memory.
Here’s a couple pics of the factory service manual schematic for a 69’ coronet/Charger
The Brown/white "extra" jumper wire is sitting in the dash harness ready to hook up to go three speed.
thanks I remember now that you said it the toughest part of the conversion is finding the switch
and crank arm and bushing
