Garner7555
As the title states, I have had the itch to add a supercharger for the past several months. I'm sure most everyone can relate to wanting more power. Below I will list my current setup that has about 1200 miles on it.
-440 block with factory steel crank and rods bored 0.030" with 2355 pistons
-The pistons sit 0.018" down in the hole and the valve reliefs account for 7cc dish
-I have sidewinder heads that advertise a 84cc chamber http://www.mopartsracing.com/parts/Sidewinder.html
-My current head gaskets are 0.040"
All of this equates to 9.7:1 compression ratio and 0.058" quench if the calculators are correct.
I already have a different EFI setup ready to install that is capable of tuning with boost (this is a lot of why I'm looking at adding a supercharger) https://www.edelbrock.com/pro-flo-4...ysler-rb-413-426-440-engines-black-35923.html
This setup is capable of supporting 975 HP with larger injectors and boost. I am not looking to make anywhere near that much power, I just wanted to let people know about this option.
I really like the Edelbrock tuning software from the small amount of looking I have done. For example, it gives you the ability to retard the timing based on the psi of boost.
Now to the real question, my compression is a little high for a boosted application. What I am considering is running my current setup, other than a boost friendly cam change, and only running 3-5 psi of boost. Do you think this is a possibility to work well? I know that I will have to use an intercooler with the multi-port fuel injection. Is anyone on here running boost on a setup remotely close to mine?
My goal would be to make 500 -550 hp at the flywheel. With a better bottom end and lower compression ratio I could bump the boost levels up and make lots more power, but I don't really want to go that route currently.
supercharger setup - http://www.torqstorm.com/kits_single_big-block-mopar.html
I really like that they offer this as a kit with all accessories and serpentine belt setup that will fit behind the supercharger belt setup. I have already been wanting to swap to serpentine belt setup.
I also like that this runs in it's own oil and doesn't use engine oil.
